12-11-2018, 08:51 AM | #76 |
Member#: 59892
South East
Vehicle:2004 TP Tuned GT30R .82 JBP STi |
Its the same wire as in the original post. I just did this with my 04 STi a couple of weeks ago.
12-11-2018, 09:21 AM | #77 |
Member#: 373868
Tri-State
Vehicle:'04 STi WRB |
01-14-2019, 03:10 PM | #78 |
Member#: 208672
TXIC
Vehicle:2013 WRX STI Limited Obsidian Black |
I've had this done to my car and it's very convenient for AP to log from wideband, BUT now this sets my O2 sensor in "not ready" state and makes the emission state inspection fail.. Anyone else run into this?
01-15-2019, 04:12 PM | #79 |
Member#: 496518
Vehicle:2014 STI Hatch |
Im late to the party
01-17-2019, 11:12 PM | #80 |
Member#: 484841
HIIC
Vehicle:2019 WRX STI |
No, you only need the updated version of ATR. I don't remember the exact version, I think it was introduced after they started forcing people to take the class. I don't run the new version of ATR so I just tap into the TGV harness and do the conversion in excel, works perfectly fine and will work with all versions of ATR.
01-18-2019, 11:40 AM | #81 |
Member#: 469585
W. Canada
Vehicle:2009 STi White |
I could be misunderstanding what you're saying so forgive me but... If you want to log/view custom sensor inputs you need to supply ATR with the voltage over data point information for that particular sensor so it can be converted into usable information. For that, you would need access to ATR or a Pro Tuner to do so.
01-18-2019, 10:14 PM | #82 | |
Member#: 484841
HIIC
1. Get the latest version of ATR, wire up the AFR serial output with a DB9 and the appropriate USB converter if you don't have a serial port on your PC. To log with this method, you will both the AccessPort and the UEGO plugged into different USB ports simultaneously. This is the suboptimal option since it requires a lot of clumsy wiring, you will have sync issues with aligning the UEGO output with the AccessPort. 2. Use the latest version of ATR, wire up the AFR output to either the Rear O2 Sensor or TGV. The custom sensor option in ATR allows you to log this data natively and it is automatically converted and displayed in the right units. This is probably the most ideal path but it wont work for folks that run an ATR version that was released before 2016. 3. The last and most universal option (for folks with deleted TGVs). Wire the UEGO into the TGV (its just one wire). Log like usual but include the appropriate TGV voltage (left or right). When you log like this, all you need to do is convert the AEM voltage to AFR using a simple linear equation. I believe it amounts to: 2 x TGV Volts + 10. I arrived at this using AEM's scaling data provided in their documentation. I haven't had a problem with this approach. Option 3 doesn't require ATR directly. You can do the conversion in excel but if you plan to use the data to change the map, you'll obviously need ATR. Last edited by slow.wagon; 01-26-2019 at 10:22 PM. |
02-03-2019, 09:43 PM | #83 | |
Member#: 497311
02-14-2019, 09:32 AM | #84 |
Member#: 373868
Tri-State
02-26-2019, 12:11 PM | #85 |
Member#: 1994
Vehicle:2018 STI WRB |
02-27-2019, 06:43 AM | #86 | |
Member#: 494821
Sorry to bump an old thread. For 0-5v white wire, is it just getting tapped into the ECU wire, or is the ECU wire totally get cut and getting wired into the gauge 0-5v wire?
03-01-2019, 05:36 PM | #87 |
Member#: 1994
It is hard to tell in the pics, but he's cutting the line completely and sending the 0-5v from the WB to the ECU. You can kinda see the cut end of the wire peeking out of the wrap in the pic where the new line is spliced in.
06-07-2019, 09:52 AM | #88 |
Member#: 346697
Vehicle:2002 WRX |
I would not recommend cutting the ECU wire. Just re-use the rear O2 sensor harness and re-route is through the firewall. I made a video showing the install on an 04 STi:
07-31-2019, 08:56 AM | #89 |
Member#: 504787
So is this the same for an 04 wrx? If so is the wire color the same? Basically trying to connect the AEM wideband afg to my ap2 for data logging.
08-06-2019, 07:25 AM | #90 |
Member#: 504787
Is the wire the same color on 04 wrx? This is extremely helpful
09-08-2019, 07:59 PM | #91 |
Member#: 504761
09-15-2019, 03:48 AM | #92 | |
Member#: 452918
South East
Vehicle:2003 Subaru Outback White |
10-14-2019, 11:37 AM | #93 |
Member#: 500444
do you have to have a controller in this scenario or just need to pin the white wire over to the ecm input and give it power and ground?
10-14-2019, 12:16 PM | #94 | ||
Member#: 138994
Vehicle:2006 WRX, 6MT, 5x114 |
Since the ECU does not have an internal controller there needs to be some sort of lambda (WBO2) controller involved and then the analog output from that external controller goes to that "white wire" ECU input circuit. Either is is a separate controller w/o a gauge face [ex. Innovate LC2] or the controller is integrated into a gauge face [ex. AEM UEGO] |
10-15-2019, 05:22 PM | #95 | |
Member#: 500444
10-16-2019, 08:16 PM | #96 |
Member#: 239430
South East
Vehicle:2013 STI sedan White |
Very helpful thread!
anyone know the best place to ground the brown analog ground wire on an x series AEM gauge? Grounding to chassis is making my readings off on my AP3. AEM Instructions call for a "sensor ground" but it's not clear exactly where this is. Cant find a description of each wire on sensor harness - tried black but it don't work. |
10-16-2019, 09:04 PM | #97 |
Member#: 452918
South East
I contacted aem when installing mine and they said to use the same ground I tapped into for the black wire. It has worked well for me.
10-17-2019, 06:46 AM | #98 |
Member#: 239430
South East
Thanks Nick 93: to be sure, u mean the black wire on sensor harness? I assumed this was ground, but AEM diagrams don't say....
12-10-2019, 01:11 PM | #99 |
Member#: 509188
Has anyone done this using the prosport gauges? I have the dual setup (afr/volt) and was wondering if I just tap into the grey output signal and connect it to the rear o2 signal wire?
12-29-2019, 12:20 AM | #100 |
Member#: 424131
South East
Vehicle:2006 WRX Limited Aspen White |
I also need help with the brown wire on my AEM X Series. When I connected it with my black ground wire to the exact same ground place as the black wire the gauge stays on 24/7 even when the car is off and key is out. Only way to make it turn off is to remove the fuse tap. I can confirmed that the fuse tap is tapping a circuit that has no power with key out. When I remove the Brown wire from ground the gauge stays off with key out. Doesn't seem right!
