08-16-2019, 07:22 PM | #1 |
Member#: 2272
BAIC
Vehicle:2019 Macan 4cyl 1993 Impreza FWD WRX swap |
Kost's "Camo Wagon" 1999 Outback Sport Safari Build
I've been meaning to start a thread on this build for awhile but haven't gotten around to it...
I purchased a 1999 Outback Sport in 2017 for $2000 (going rate for running cheap N/A Subarus in Norcal) with almost 300,000 miles on it with the intention of really just having something to work on at the time, a project car to build with my knowledge of the Gen-1 Impreza platform having had a 1995 Coupe for almost 10 years. The car I purchased I found had a ton of miles, but the body itself was solid with no rust and no major dents or dings in the metal parts of the body. The interior was pretty good as well, but I had full intention of completely cleaning the car from the inside out as well as fully replacing the suspension components and most of the car in general. Its hard to go over the whole thought process being almost 2 years after buying the car, so I'll just start by saying I decided to go with a mild-lift, over-land type "Safari" build for the car with the intention of using it for bad weather daily driving and mild off-roading. For the drivetrain, I decided to stick with the 2.2L N/A motor with the intention of building the most Durable and Reliable Subaru motor possible (IE Non-turbo, non-2.5L headgasket chewing motor). The motor is currently being rebuilt due to finding metal shavings in the oil (Photos of the rod bearings will be in this thread) and is a bit of an experiment, utilizing cylinder heads from a JDM EJ202 SOHC motor that have dual exhaust ports and basically bolt on to the EJ22 block. Should bump up the compression as well like other frankenstein motors. I will be adding an oil cooler, larger oil pump and killer B pan for beefing up the motor for heavier duty use. I also decided to go with upgraded differentials with involved swapping in a VTD 4EAT and Viscous rear LSD after reading a thread or two about the VTD conversion for 4EAT's giving a better power distribution and planetary center differential. Sadly a LSD front diff is not in order for this car, as it was with my '95. The suspension started off with the goal of a full TSS-Fab setup, which I wound up finding used. Used in conjunction with upgraded bushings all around and STI struts using WRX springs and Group-N tophats (commonly used for Rallyx setups). I used Forester struts before for a lift on the '95, but didn't want to lift it too high this time. I found a used TSS-fab setup for Gen 2 Impreza but the front subframe wasn't compatible with the 4EAT. It was the more "hardcore" option with solid metal bushings all around, which worked OK for awhile but turned out to be too rough for a daily driver and have since swapped to a more traditional control arm setup while keeping the TSS-fab rear subframe and T-bar. The Camo idea came due to the use of the car and trying to decide what to do about the paint. I didn't want to spend a lot of money repainting parts of the car and experimented with Vinyl on another car and wanted to try a whole car myself. The decision to go with desert camo two-tone was two fold - One, the Camo made it easier to hide my mistakes during the wrapping process, and two, I use the car actually for "Safari's" to local wildlife refugees in Norcal to take photos... The camo is actually functional for a change! The two tone black bottom came because of the bumpers being rather hard to wrap and keeping with the two-tone Outback sport them worked well with some photoshoping. Anyway, here is the current mod list: Engine "Frankenstein" Build by M45 Automotive: EJ22 Shortblock Bored and decked with New Pistons King Bearings EJ20 JDM SOHC Cylinder heads (for dual ports and higher compression) Valve job and machined heads 10mm Oil Pump Killer B Oil Pan OEM Oil cooler Current Mods: Cobb Intake for MAF cars STI muffler w/ custom tip Ebay Header (Borla replica?) Group-N engine mounts Group-N Pitch Mount Rallitek 4EAT Transmission bushing insert JDM 4.11 4EAT with VTD 4.11 rear VLSD 2015 STI steering rack Sparco Terra 15x7 +50 in Bronze Yokohama Geolander A/T G015 205/70r15 2.5RS front brake calipers/Stoptech calipers WRX rear calipers/Stoptech Rotors Stoptech Pads Stoptech Brake lines STI Struts WRX springs Group-N front top hats Cusco Rear Strut bar Unknown Front Strut bar 2002 RS front swaybar Removed rear swaybar & mounts TSS Fab rear subframe TSS Fab T-bar SPC Rear Adjustable Control Links Manzo (Ebay) rear trailing arms Superpro Trailing Link bushings (on hub) Whiteline front control arm bushings MOOG Ball Joints 2002 RS front subframe Digital Desert Camo Wrap 3M Gloss Black wrap Depo Headlights/Orange Corner lights 2.5RS front bumper New rear bumper Light weight bumper beams front and rear CF Foglight covers Rally Innovations Light Bar Generic 12" Light bar on bumper JDM Tail lights Tow hitch Front Skidplate from 2000's Outback Rhino Rack Mesh Roofrack DIY Wheel Roof Rack Mount Yakima fairing EDM black leather wagon seats Wood trim steering wheel OEM Compass dash mount w/ Radio moved to upper DIN OEM Dual Cupholder Duplicolor Vinyl painted interior panels (lower half) Black bedliner painted trunk bits New OEM dark grey carpet New floor mats (found in my attic lol) Weathertech Floormats (modified to fit) Photos as of course this is the Photo gallery... First off, the car won "Organizers Choice" at B.A.M. last year! A few photos of the car as it is right now, including the new roof mounted spare: What the car looked like when I purchased it: More updates to come!
08-16-2019, 07:23 PM | #2 |
Member#: 2272
BAIC
Here are some pics from the last couple years showing some minor changes as I went, along with the application of the Camo Vinyl wrap:
08-16-2019, 07:23 PM | #3 |
Member#: 2272
BAIC
Here are a couple before pics of what the car looked like underneath when I purchased it:
And here are a couple from 2018 after the mods and a lot of cleaning/painting: The interior required A LOT of cleaning due to the car being used daily on dirt, rock covered roads going up and down the sierras kicking up dust everywhere inside the car... At this point, I've removed and cleaned (or repainted) basically every interior panel minus the roof/pillars and dash: The new carpet during the install. The leather seats were installed prior, and they took a little repair/restore work too: Last edited by Kostamojen; 08-16-2019 at 07:34 PM. |
08-16-2019, 07:23 PM | #4 |
Member#: 2272
BAIC
Took the car up to M45 Automotive for some major surgery a couple weeks ago...
It failed smog in March due to a bad cat and maybe O2 sensor (had aftermarket cats) and had debris in the oil as I mentioned along with some oil leaks on the engine, transmission, and power steering lines that are getting repaired. The teardown revealed the damage to the rod bearings, which considering I've put maybe 3000 miles on the car, were from the previous owners: Last year I picked up this EJ202 from a local JDM place for cheap. Disassembled it myself and had the heads refurbished for going on the EJ22 shortblock, I'll get more photos of the motor build in progress soon: Last edited by Kostamojen; 08-16-2019 at 07:36 PM. |
08-20-2019, 05:09 PM | #5 |
Member#: 329493
RMIC
Vehicle:1999 Impreza 2.5RS Black Diamond Pearl |
I remember seeing your car at BAM last year. Didn't realize it was yours!
08-21-2019, 03:01 PM | #6 |
Member#: 505487
Car looks sweet! I'm digging the theme!
08-21-2019, 03:34 PM | #7 |
Member#: 2272
BAIC
08-30-2019, 04:49 PM | #8 |
Member#: 2272
BAIC
More photos of the engine build as promised...
New plus sized pistons installed with bore & decked 2.2L block: Herea are the N/A EJ20 SOHC phase II heads. EJ203 I think, might be EJ202, I forgot which is which: 10mm pump, added OEM oil cooler, and Killer B oil pan: Extra picks M45 just sent me showing the work in progress: |
10-12-2019, 12:49 AM | #9 |
Member#: 2272
BAIC
Few updates.
Car is running great with the new motor. Did have a small snafu with the brand new timing belt failing, had to take it back to the shop. Wound up swapping the STI struts for Forester struts to get a better ride. Was having issues with the STI strut "pogo" effect that people mention when they are paired with different springs. Car rides MUCH better with the Forester struts now. Surprisingly though, it didn't lift the car any higher...??? Even though the STI struts do technically sit lower, the fact they were a stiffer strut I guess kept the car at a higher height: Also swapped out the Leather seats for JDM WRX cloth seats (from Peter on Facebook, the dude who ships GC/GF parts from the UK for damn cheap). They sit about an inch or more lower than the leather seat did, plus they have way better bolstering. I like the cloth quality too. Took the opportunity to add some Dynamat to the car while waiting for the seats, something I've always wanted to try in a car and this car could use it as it was quite loud. Definitely a noticeable change right off the bat starting the car, dropped quite a few decibels at cruising speeds too. Was SUPER easy to do and probably a good idea for older cars. |
10-13-2019, 06:11 PM | #10 |
Member#: 105310
Really nice look! The front bumper and light bar give it a real 'business' look, like it's built for a purpose not just to be flashy. Also like the spare tire mount approach... simple and not permanent.
10-13-2019, 09:09 PM | #11 |
Member#: 2272
BAIC
I'm actually trying to figure out a way to maybe get the spare to sit lower on the roof and be more aerodynamic and have a more permanent roof rack... This rack is basically just held on by clamps, and they can get loose.
10-16-2019, 05:42 PM | #12 |
Member#: 2272
BAIC
Went out to Folsom Lake to do some dirt driving and take some pics... ALMOST got stuck in a couple feet of sand, but the VTD center and viscous rear diff did its job and pulled through at about half throttle.
10-16-2019, 07:44 PM | #13 |
Member#: 2272
BAIC
Its interesting how different the color of this camo shows up with different cameras... Those were with my DSLR, this one here was with my phone and the color looks more accurate to real life with the phone:
10-18-2019, 01:20 PM | #14 |
Member#: 145105
Vehicle:2015 Honda Accord |
Nice! Subscribed.
11-09-2019, 06:02 PM | #15 |
Member#: 2272
BAIC
Photo the Camo Wagon out in its natural environment today...
I have a new roof box coming to add to the roof rack. Should be interesting. |
11-22-2019, 05:53 PM | #16 |
Member#: 2272
BAIC
Finally got my "rolling blind" setup. Folds right into the cargo box I found...
