Tire & Wheel Forum sponsored by The Tire Rack |
10-11-2019, 04:26 PM | #276 |
Member#: 449337
I heard there was a fitment issue going coilovers on the 18x9.5 +45 wheel size. Is this true? I did plan on going some coils but I didn't want to rub the suspension.
10-11-2019, 08:21 PM | #277 |
Member#: 507304
Hey guys! I have a 2020 WRX Premium with the 4pot brembo brakes. Are there any 17" wheels that will work with this? I live in a heavy winter area and would like to downsize from my 18"s
10-14-2019, 11:20 AM | #278 | |
Member#: 18261
MWSOC
Vehicle:2002 Impreza WRX w/ V9 Spec-C EJ207 |
MOST 17" wheels will clear, spoke clearance is more of a concern. |
10-14-2019, 08:06 PM | #279 |
Member#: 507304
Thank you for the information. Are there any specific wheels you can point me towards? Or what should I be looking for when it comes to spoke clearance?
10-17-2019, 01:28 PM | #280 | |
Member#: 120
AKIC
Vehicle:1997 Legacy 2.5GT 1996 Impreza coupe |
Edit: If you're using OEM Subaru Brembos, see the sticky threads - https://forums.nasioc.com/forums/sho...d.php?t=448097. Last edited by Patrick Olsen; 10-17-2019 at 02:06 PM. |
10-17-2019, 02:07 PM | #281 | ||
Member#: 18261
MWSOC
(and the same bolt pattern) Did you have a style, or brand, or maybe color in mind? Send me a PM, I'd love to help you out! Quote:
I honestly didn't even realize what thread this was in, we were all new here once... |
10-18-2019, 09:39 AM | #282 |
Member#: 295970
Tri-State
Vehicle:2019 STI CWP |
19 sti, using my winter set up from my old wrx
225/45/18 with Koni Rajin with offset of 50 I should be ok on stock suspension? Last edited by vlad11591; 10-21-2019 at 02:45 PM. |
11-14-2019, 04:51 PM | #283 |
Member#: 431318
NESIC
Vehicle:2016 WRX STi Limited Lapis Pearl Blue |
Following up on this-- does anyone know if the 18+ WRX wheels fit over the 2018+ STI brembos?
11-14-2019, 04:53 PM | #284 | |
Member#: 431318
NESIC
11-14-2019, 05:36 PM | #285 | |
Member#: 250084
Tri-State
Vehicle:2019 STI Pure red |
I just hope you are not spending 275 bucks a rim on stock wheels for winter. Way better options. |
11-30-2019, 04:45 PM | #286 |
Member#: 378779
NESIC
Vehicle:2019 WRX STI CWP |
Will the 2011 OEM Enkei STI wheels fit my 2019 STI? Picking it up tomorrow for my winter set up.
12-06-2019, 05:41 AM | #287 |
Member#: 401922
BAIC
Vehicle:2018 STi WRB |
12-21-2019, 12:20 PM | #288 |
Member#: 509567
Vehicle:2019 STI ISM |
12-21-2019, 03:21 PM | #289 | |
Member#: 509567
12-21-2019, 07:07 PM | #290 | |
Member#: 302548
Vehicle:2019 Golf R 2018 High Country |
Your easiest bet is to just download the Tapatalk app. |
12-21-2019, 10:09 PM | #291 |
Member#: 509567
Downloaded the app. Here’s the pics of the 18” wrx wheels
01-13-2020, 05:58 PM | #292 |
Member#: 194785
Cross posting from the 2015 STI wheel fitment thread. Just found this thread so I guess I should have posted here first.
======= Here are some test fit shots of a Motegi Traklite 3, on an otherwise stock car. They are 18x9.5 et45. Going to be fitting a set of 265/35zr18 tires on them for autox. Tires will be mounted next week. I did a better test going full lock left and right but realized that until I've got the tires fit it's pretty much useless info. |
01-18-2020, 07:34 PM | #293 |
Member#: 233053
Those are nice motegi wheels. Can't wait to see them with tires and on the ground!
01-23-2020, 01:50 PM | #294 |
Member#: 194785
Wish I had some better shots. Have been too busy to go for a real drive. Edit:. I should add that the clearance is good at static stock height. Not sure if that will remain the same while under an autocross run. I'll know on the 1st and 2nd of February. |
01-24-2020, 06:03 AM | #295 |
Member#: 33990
xpystchrisx, anyway you could get a straight on side picture? trying to see what the fender gap looks like from the side with your fitment.
Sweet color combo also good choice. |
01-24-2020, 07:30 AM | #296 |
Member#: 194785
Let me know if that works. I can get some daylight shots later today. Still has all of the soap from install on the tires. |
01-24-2020, 01:01 PM | #297 |
Member#: 33990
Works great man appreciate the shots. What is that like a 3 finger gap front rear? Trying to decide between 255/40 and 265/35 w stock suspension is why I am asking.
Thank you Last edited by waitandbleed92; 01-24-2020 at 01:07 PM. |
01-24-2020, 01:32 PM | #298 | |
Member#: 194785
I like the 265/35. I will know how they perform early next month. |
02-18-2020, 09:35 PM | #299 |
Member#: 195423
TXIC
Vehicle:2001 2.5 RS BRP |
02-21-2020, 07:08 PM | #300 |
Member#: 195423
TXIC
