06-28-2019, 11:38 AM | #7826 | |
Member Sales Rating: (1)
Member#: 135051
TXIC
Vehicle:2006 WRX Waggy Black |
Thank You Thank You for the advice and recommendation!! I will be using a GS 3 Port EBCS on this setup for sure. You’re absolutely right. May as well upgrade...it’s all 13 year old components to say the least. I do already have the boost controller in hand but will need an invoice for the plugs and tune if you don’t mind sir. I know you’re busy...no rush at all.
06-28-2019, 11:43 AM | #7827 | |
Member#: 135051
TXIC
Hey Clark...just realized I forgot to tell you I am located in 70591 Southwest Louisiana...and will be using 93 Octane Fuel. (-: |
07-15-2019, 12:01 PM | #7828 |
Vendor Sales Rating: (68)
Member#: 178047
SWIC
Vehicle:02 WRX STI Spec C Black |
All maps sent out.
__________________
Clark Turner Tuning To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. 480-695-2898 Send TXT message for faster response. [B]PLEASE "LIKE" "Clark Turner Tuning" On FACEBOOK for dyno charts and daily updates[/B] |
07-16-2019, 12:59 PM | #7829 |
Member#: 178047
SWIC
All maps have been sent out
C
__________________
07-22-2019, 11:20 AM | #7830 |
Member#: 178047
SWIC
All maps sent out
C
__________________
08-02-2019, 02:03 PM | #7831 |
Member#: 178047
SWIC
__________________
08-14-2019, 11:30 AM | #7832 |
Member#: 178047
SWIC
All maps sent out
__________________
08-19-2019, 01:43 PM | #7833 |
Member#: 178047
SWIC
__________________
08-22-2019, 11:39 AM | #7834 |
Member#: 178047
SWIC
__________________
08-23-2019, 11:57 AM | #7835 |
Member#: 320805
Just ordered a customer tune for my 03 wrx! You did great on my 1995 impreza wagon with 07 sti swap. Didn't even think of going anywhere else with my new car! I am running the cobb stage 3 map for now so no rush. Thanks for your work!
09-01-2019, 11:13 AM | #7836 |
Member#: 178047
SWIC
All maps sent out
C
__________________
09-03-2019, 10:40 AM | #7837 |
Member#: 178047
SWIC
All maps sent out
__________________
09-05-2019, 12:47 PM | #7838 |
Member#: 178047
SWIC
C
__________________
09-09-2019, 04:00 PM | #7839 |
Member#: 178047
SWIC
All maps sent out
__________________
09-10-2019, 12:36 PM | #7840 |
Member#: 178047
SWIC
All maps sent out
__________________
09-13-2019, 12:53 PM | #7841 |
Member#: 178047
SWIC
All maps sent out
C
__________________
09-16-2019, 12:48 PM | #7842 |
Member#: 178047
SWIC
All maps sent out
C
__________________
10-10-2019, 02:36 PM | #7843 |
Member#: 178047
SWIC
All maps sent out
c
__________________
10-16-2019, 12:25 PM | #7844 |
Member#: 178047
SWIC
all maps sent out
__________________
10-17-2019, 08:03 PM | #7845 |
Member#: 178047
SWIC
__________________
10-18-2019, 11:04 AM | #7846 |
Member#: 178047
SWIC
All maps sent out
__________________
10-19-2019, 09:08 PM | #7847 |
Member#: 499465
MWSOC
Vehicle:2011 STI WR Blue |
Need direction...
Hi Clark, been going over your thread and was looking to do a build on my 11 STI. Well must do it now because it spun a bearing and the shop put wiseco .020 over and eagle rods in for me. Now i've always read that you should contact a tuner about build specs before buying parts. So this is it and you are he. The car when I bought it had a cobb v2 AP, cobb cold intake and I assume cobb exhaust. The stock turbo has cracked so it needs to be replaced. I bought the Tomioka Racing Top Feed Fuel Rail Kit because its parallel and that's all so far. Good fuel is hard to find in my area but at least it's ethanol free. I'm looking for around 500hp
I was looking at AMS Front Mount Intercooler Kit Blouch Dominator 3.5XT-R Torque Solution Top Feed TGV Deletes Radium Engineering Fuel Hanger w/wal 400lph What injectors do you think I should get and if a fuel surge tanks recommended. Any other recommended parts? What your fuel map tune will cost? Should I or do I need to get the AP v3 for your maps? Or should I just buy whatever I want and give you the final specs for the tune? |
10-20-2019, 08:29 PM | #7848 | |
Member#: 178047
SWIC
C
__________________
10-20-2019, 08:41 PM | #7849 |
Member#: 499465
MWSOC
AP v2
The AP v2 can't be updated because I don't have an older OS than windows10 so its somewhat useless. I can't get E85 and the closest 93oct is 70 miles away from my house. I was looking at those Cobb 1300x's and just need to make a finale decision on the turbo but the fuel rails are on the way. I OTR drive and will be on the road for a couple of weeks and I'll send that email a week before I return so it can be here when I get home.
Thanks Clark |
10-21-2019, 10:29 AM | #7850 | |
Member#: 178047
SWIC
C
__________________
Similar Threads | ||||
vf39, Clark Turner map...still need more | Mark11 | Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) | 40 | 09-01-2009 10:29 PM |
clark Turner mizer map vs OTS Cobb | Leggy_09 | AccessPort | 6 | 08-22-2009 12:26 AM |
Clark Turner mizer map vs OTS Cobb | Leggy_09 | AccessPort | 1 | 08-18-2009 10:23 PM |
No Cobb Vf39 - Protune Map Release? | Need BB | Engine Management & Tuning | 14 | 11-08-2005 12:39 PM |
Cobb PROTUNER Release? | aspenwhitewrx | Engine Management & Tuning | 4 | 03-15-2005 04:19 PM |
