02-25-2019, 02:38 PM | #7801 |
Vendor Sales Rating: (68)
Member#: 178047
SWIC
Vehicle:02 WRX STI Spec C Black |
__________________
Clark Turner Tuning To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. 480-695-2898 Send TXT message for faster response. [B]PLEASE "LIKE" "Clark Turner Tuning" On FACEBOOK for dyno charts and daily updates[/B] |
02-27-2019, 11:36 AM | #7802 |
Member#: 178047
SWIC
All maps have been sent out
C
__________________
03-02-2019, 11:39 AM | #7803 |
Member#: 178047
SWIC
All maps have been sent out.
__________________
03-15-2019, 06:41 AM | #7804 |
Member#: 431267
I have a bone stock 2018 STI.
Was curious about going E85 and had some basic questions. I also dont want to modify the car too much. I had a bone stock CTT e85 2015 WRX and really loved it. I have the cobb ap and I know cobb offers the ethanol sensor kit. What would be the difference in HP/TQ from stock to e85 with your tune versus e85, fuel injectors, and a fuel pump with your tune? What would you suggest as far running e85 with as little modifications as possible? Just picking your brain because I really loved my previous CTT. Thanks Leroy |
03-15-2019, 09:10 PM | #7805 | |
Member#: 178047
SWIC
C
__________________
03-18-2019, 12:36 PM | #7806 |
Member#: 178047
SWIC
C
__________________
03-25-2019, 02:17 PM | #7807 |
Member#: 178047
SWIC
__________________
03-28-2019, 12:27 PM | #7808 |
Member#: 178047
SWIC
C
__________________
04-01-2019, 03:42 PM | #7809 |
Member#: 178047
SWIC
C
__________________
04-16-2019, 12:42 PM | #7810 |
Member#: 178047
SWIC
C
__________________
04-21-2019, 11:10 AM | #7812 |
Member Sales Rating: (1)
Member#: 498619
Vehicle:2018 STI |
2013 Subaru WRX (Hatchback) - Have Cobb AP v3 w/ Cobb SF Intake. Going to get full Cobb exhaust with downpipe. Which one would everyone recommend for more power, replace TMIC with better aftermarket one, or do a FMIC? (Currently running AP set to STAGE 1 + SF (using 93)).
Upon reading much of this forum with still some to go - before getting either TM or FMIC , it's best to get a good recirc value, and a DW65C fuel pump? Thoughts on A/O separator? Thanks in advance everyone. Last edited by lowpro3210; 04-22-2019 at 05:12 PM. |
05-22-2019, 06:50 PM | #7816 |
Member#: 498619
Vehicle:2018 STI |
Is a tune needed after install Dw65c? Had one of the techs at work install and car ran like ****. Inconsistent idles, fuel pump going from 33,66,100. Car stalled at one point. Had him put OEM fuel pump back in and went away. Bad fuel pump or needs tuned after pump install? Figured after injectors it would obviously needed tuned...any help is much appreciated
05-22-2019, 07:01 PM | #7817 | |
Member#: 178047
SWIC
C
__________________
05-24-2019, 10:43 AM | #7818 |
Member#: 498619
Vehicle:2018 STI |
Absolutely correct on that one Clark! Brought this to his attention and redid it with o ring and works like stock now I'll be getting a protune from you within the next couple of days. Thank you so much!
06-14-2019, 09:23 AM | #7819 |
Member#: 178047
SWIC
C
__________________
06-14-2019, 09:35 AM | #7820 |
Member#: 498619
Vehicle:2018 STI |
Getting ready to put my order in by tonight for your site. Running Cobb 2.5 inch full turbo back exhaust. Is it advisable to remove the cats? If so, can you make the new map clear the CEL if it comes on from removing cats? Or do you recommend keeping them? Emissions...meh. Pros, cons?
06-14-2019, 09:47 AM | #7821 | |
Member#: 178047
SWIC
C
__________________
06-14-2019, 01:59 PM | #7822 |
Member#: 15060
MWSOC
Vehicle:2015 WRX MAPerformance Stage2+ E30 |
I just want to confirm the pricing on your site for the Cobb flex fuel kit and flex fuel E-tune. Is $800.00 correct for the combo if we order the kit from you?
That is a hell of a deal for the Cobb kit and a flex fuel tune. |
06-14-2019, 02:46 PM | #7823 | |
Member#: 178047
SWIC
C
__________________
06-28-2019, 04:03 AM | #7824 |
Member#: 135051
TXIC
Vehicle:2006 WRX Waggy Black |
Hey there Clark...
I’ve got a 2006 WRX Wagon 5MT with a VF48, ID1000cc Fuel Injectors, 2013 STI TMIC, IAG AOS, AEM Fuel Pump, 3” Catless Turbo Back Exhaust, Cone Shaped AFE Air Filer (stock inlet tube) and a Turbo Smart BOV... ...Wanted to know if you thought I needed to upgrade to a GS/Cobb Boost Controller, and 1 step colder NGK or Denso spark plugs before purchasing a tune from you...? Also I would like to delete the air pump under the hood...is that cel something you could delete via the tune? Thanks so much, John McGee |
06-28-2019, 10:16 AM | #7825 | |
Member#: 178047
SWIC
I would recommend NGK2309 plugs for this setup. A 3 port is a good idea. By now your stock boost control lines are probably worn and need replacement anyways and with a 3 port, the lines will be new. When you are ready just order the custom protune map on my website. Or let me know if you need the parts and I can send you an invoice for the plugs, 3 port and tune.
C Quote:
__________________
Similar Threads | ||||
vf39, Clark Turner map...still need more | Mark11 | Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) | 40 | 09-01-2009 10:29 PM |
clark Turner mizer map vs OTS Cobb | Leggy_09 | AccessPort | 6 | 08-22-2009 12:26 AM |
Clark Turner mizer map vs OTS Cobb | Leggy_09 | AccessPort | 1 | 08-18-2009 10:23 PM |
No Cobb Vf39 - Protune Map Release? | Need BB | Engine Management & Tuning | 14 | 11-08-2005 12:39 PM |
Cobb PROTUNER Release? | aspenwhitewrx | Engine Management & Tuning | 4 | 03-15-2005 04:19 PM |
