06-02-2016, 10:33 AM | #26 |
Member#: 1910
NESIC
The house is a vinyl sided cape BTW so there's really no architectural flourish to it either. I want a plywood box and a plywood rectangle on a cement foundation covered in vinyl siding that resembles the siding on the rest of the house. That's it. There's no carriage doors, no exotic requirements. Nothing.
06-02-2016, 10:34 AM | #27 |
Member#: 141952
MWSOC
Vehicle:2023 M340i |
About 1 hour after i brushed against that damn nettle i was spraying it. Had a big itchy welt on my arm for a week. Stuff is nasty.
06-02-2016, 10:35 AM | #28 |
Member#: 150289
SWIC
Vehicle:2006 SV650, 05 CTSV 1972 Travelall |
I'd like to get rid of the fluorescent fixture in our kitchen, and put in something nicer. Do they make recessed lighting that can be installed without attic access? I don't think there's much depth between the ceiling and the roof in the kitchen.
I'm not a huge fan of track lighting, but it maybe when we have to do. |
06-02-2016, 10:39 AM | #29 |
Member#: 329599
MAIC
Vehicle:2004 STI Aspen White 2015 Jetta TDI |
Well I'll christen the new thread with a fun post.
Wife calls me while I'm at work and tells me the AC condenser decided to dump a bunch of water into the ceiling which made its way to the floor. So she shut off the HVAC and decided to just go to work... Guess I'll have to address it when I get home but this should be fun. We do have a home warranty but we're unsure which of the components will be covered whether it'll be the ceiling repair or AC unit. Definitely puts a dampener on my day, I was planning to go pick up a BNIB JDM roof vent already painted Aspen White this weekend! But not now just in case the home warranty doesn't cover this. |
06-02-2016, 10:46 AM | #30 | |
Member#: 242205
Vehicle:2009 I don't know Dirt |
06-02-2016, 10:49 AM | #31 | |
Member#: 203905
They typically look like http://www.amazon.com/Halo-H7RICT-Housing-Remodel-Voltage/dp/B0009J8RMA/ref=sr_1_7?s=hi&ie=UTF8&qid=1464878938&sr=1-7&keywords=recessed+lighting |
06-02-2016, 10:52 AM | #32 | |
Member#: 6590
Like this: http://www.lowes.com/pd_60554-337-H7...AID=1706932857 |
06-02-2016, 10:56 AM | #33 | |
Member#: 6590
06-02-2016, 10:57 AM | #34 | ||
Member#: 150289
SWIC
06-02-2016, 11:00 AM | #35 | ||
Member#: 134262
Vehicle:-1 centrifugal bumble-puppy |
http://www.botanicalartspress.com/bl...ot-horseradish If it's edible, it's not noxious. It's invasive and annoying (but also tasty) You apparently need to cook more lamb |
06-02-2016, 11:05 AM | #36 |
Member#: 6590
You might be able to install a few LED units if you don't mind making some holes in the ceiling.
06-02-2016, 11:45 AM | #37 | ||
Member#: 329599
MAIC
"The dishes aren't getting cleaned" "Well lets fix the utensil rack while we're in here" "So how are we going to fix the 'dish washing' part?" "Here's a new wheel for the top rack to slide on" "So how are we going to fix the 'dish washing' part?" "We should clean the drain" "..." "Here's your problem, there was a little barcode tag stuck in the drain" "Please leave my home." Quote:
Should be an easy fix but it's still something I'd rather not have to worry about when we're moving into a slight heat wave and have a newborn in the house. |
06-02-2016, 11:57 AM | #38 |
Member#: 93205
Anyone had a fireplace remodeled?
Currently, I have a gas insert but don't really care for the look of the bricks and sitting hearth. I'm in the middle of putting laminate flooring down throughout the house and it really won't look as good with this 80/90's style fireplace. Should I look for a contractor who can come up with a few ideas or hire an interior designer for a few hours to give us some ideas to present to a contractor? |
06-02-2016, 02:04 PM | #39 | |
Member#: 6590
06-02-2016, 02:34 PM | #40 | |
Member#: 143938
NWIC
<-- Needs to go spray some more weeds. Daisies are on the docket this year. I've gotten rid of most of the thistles over the last few years, but still have a few here and there. Edit: also check Farm/Garden type stores. They typically have bulk herbicides for prices that aren't too bad. |
06-02-2016, 02:46 PM | #41 |
Member#: 6590
06-02-2016, 02:57 PM | #42 | |
Member#: 140147
MAIC
Garage would be anywhere from 25-50K, plus tying into the structure...bruh, you gonna pay. |
06-02-2016, 03:04 PM | #43 |
Member#: 1910
NESIC
It would actually make more financial sense to put 30K of lipstick on this pig, sell it and buy something else that already has a ****ing garage. 70K for something that MAY add 30K to my house. **** that.
06-02-2016, 03:10 PM | #44 |
Member#: 140147
MAIC
^Sadly? Yup.
06-02-2016, 03:24 PM | #45 |
Member#: 6590
Yeah, next house I move into is going to have a garage already, or it will be built before I move in. When I moved into my current house, I had ALL these plans of 'Well the garage can go there, I can do this, that and the other thing." Then reality set in and I realized it would cost close to $15k just in site work to put it where I'd want, at the size I want, with the features I want....sorry, can't justify nearly $80k for a garage.
06-02-2016, 03:35 PM | #46 |
Member#: 15571
Vehicle:2006 06 Forester XT Silver |
$13,300 sound reasonable for a 96% efficient 100,000 BTU propane furnace with 4 ton 16 SEER heat pump/AC?
06-02-2016, 03:41 PM | #47 | |
Member#: 1910
NESIC
06-02-2016, 03:42 PM | #48 | |
Member#: 6590
Is it an easy installation or are they doing a s-ton of work to change it out? Sounds a little high to me, but I've seen worse prices for less. I found the original quote for the system that was put in my childhood house back in 1987...100,000 BTU gas furnace, and 2,5 ton A/C unit, $2,200 installed. |
06-02-2016, 03:50 PM | #49 | |
Member#: 15571
No ductwork needs to happen as it's basically a one for one replacement, although they are giving me a bigger air filter duct area thingy. Edit - I have no condenser pad currently, it's sitting on the mulch. They are putting in a crushed stone + fiberglass pad. Last edited by cwb124; 06-02-2016 at 04:02 PM. |
06-02-2016, 04:00 PM | #50 |
Member#: 13485
NESIC
Vehicle:OMG EJ22T FTW |
Yay new thread.
