Old 11-28-2013, 06:21 PM   #176
STIinthefe
Member#: 314642
2004 STI
I currently have pro sport oil temp, oil press, and boost gauges. When I bought the car two years everything worked. Now the oil pressure and boost gauge does not work now. I notice the oil pressure sender was leaking oil. I replaced it with the same sender from pro sport and still nothing. Does anyone have any advice?
STIinthefe is offline   Reply With Quote
Old 11-29-2013, 08:53 AM   #177
Prosport Gauges
Member#: 124196
Give us a call to troubleshoot. We can walk you through several things to check. 727-572-9011
Prosport Gauges is offline   Reply With Quote
Old 11-30-2013, 10:46 AM   #178
STIinthefe
Member#: 314642
2004 STI
Hey that's great. Thank you
Old 01-02-2014, 09:51 AM   #179
Bimiss
Member#: 377551
Doesn't light up or anything? I would check if its got +12V and good earth/ground.
Bimiss is offline   Reply With Quote
Old 02-07-2014, 12:58 PM   #180
Spoolsworth
Member#: 379437
2006 Limited WRX
Just thought I'd throw it out there that a few of the links for gauge manufacturers are outdated.
Here's blitz:
http://www.blitzpowerusa.com/
VDO and Omori don't seem to be making them anymore??
Spoolsworth is offline   Reply With Quote
Old 02-08-2014, 10:55 AM   #181
nepbug
Member#: 328631
2008 FXT
Here's blitz:
VDO is still in the game, they've been around a really long time and will be around for a while longer.
http://www.vdo-gauges.com
Don't expect the first post to be updated, the OP hasn't updated that in a long time.
nepbug is offline   Reply With Quote
Old 10-03-2014, 08:59 PM   #182
Silvir05
Member#: 196526
2015 FXT
Running oil px, temp, and boost gauges. At cold idle I see oil at 100psi, then above 190 deg it calms down to 20psi. However when Im driving at 200-220deg, I only get between 40-50psi partial throttle and WOT. Is my oil pump going out? 5w-50 viscosity
Sent from my SM-G900V using NASIOC mobile app
Silvir05 is offline   Reply With Quote
Old 10-06-2014, 09:48 AM   #183
Prosport Gauges
Member#: 124196
Don't think so, once the oil is heated up it's thinner and thus your OP will be lower even during WOT
Old 10-07-2014, 01:40 AM   #184
IllustriousBrown
Member#: 200355
2006 WRX Wagon
WRB, Cobb Stage 2
5w-50??? Why? But those numbers seem about right. Before mine started acting really, really weird I was 100/20 idle, and 120/40-60 on the gas. 80 while driving normal, but not quite warm, not quite hot.
IllustriousBrown is offline   Reply With Quote
Old 01-20-2015, 08:53 PM   #185
Silvir05
Member#: 196526
2015 FXT
I run that high viscosity due to the built engine clearances, forged pistons, blueprinting, etc
Old 01-22-2015, 02:14 PM   #186
TheMonaLisa
Member#: 357722
2006 Legacy GT
With current afr wideband gauges having advanced so much, are the top three gauges still boost, egt, oil press? I was leaning towards boost, wideband, oil press/ temp combo as my three.
TheMonaLisa is offline   Reply With Quote
Old 01-22-2015, 02:19 PM   #187
Prosport Gauges
Member#: 124196
I always recommend Wideband, boost, oil pressure, then depending on your fuel system a fuel pressure gauge.
Old 01-26-2015, 09:09 AM   #188
TheMonaLisa
Member#: 357722
2006 Legacy GT
At what fuel mod point do you recommend a fuel press gauge? Im planning for a simple drop in pump and injector swap. Thanks for the previous reply.
Old 01-26-2015, 09:23 AM   #189
Prosport Gauges
Member#: 124196
If its a simple walbro 255/450 drop in pump youll be fine without one. If you have the room its always good, because pumps do fail.
On my vehicle I run a single 450 e85 without a gauge, but Im adding a secondary pump and fuel pressure regulator. So I will be adding one of our clear lens premium gauges with the warning.
Old 03-22-2015, 02:23 AM   #190
Array
Member#: 356689
2004 WRX
Nice post! Thanks Unabomber. Much info.
Array is offline   Reply With Quote
Old 04-22-2015, 11:50 AM   #191
Nirvana
Member#: 380338
2006 Impreza WRX STi
Crystal Grey Metallic
Does anyone have another link to the OEM 3 gauge pod? Or any replacements that fit / look the same as the hawkeye trim?
Nirvana is offline   Reply With Quote
Old 04-22-2015, 01:25 PM   #192
tekfoc
Member#: 21392
2018 E63S AMG MB
Black/MB
here you go had it on my old 07 STI.
http://www.zerosports-america.com/st...m9k6o5ofr5ivr2
tekfoc is offline   Reply With Quote
Old 04-22-2015, 01:37 PM   #193
Nirvana
Member#: 380338
wow that was fast. Thanks!!
Old 04-22-2015, 01:38 PM   #194
tekfoc
Member#: 21392
2018 E63S AMG MB
Black/MB
NO PROBLEM.
Old 05-05-2015, 06:31 AM   #195
WhatsASubie
Member#: 362544
2013 Wrx
satin white pearl
my coolant temp has been as high as 216f should i be concerned? It usually doesnt go over 207
WhatsASubie is offline   Reply With Quote
Old 06-14-2015, 09:59 PM   #196
teufel_4
Member#: 355745
2013 Impreza Sport
Venitian Red
Where would the gallery plug be located on a 2.0 engine?
teufel_4 is offline   Reply With Quote
Old 06-15-2015, 04:10 AM   #197
SubiKidd04WRX
Member#: 423573
2004 Impreza WRX
What is a good a-pillar gauge pod to get? I'm looking at triple gauge pods but I herd that GlowShift ones are crappy.
SubiKidd04WRX is offline   Reply With Quote
Old 06-15-2015, 06:18 AM   #198
Noximus
Member#: 368550
2009 STI Sport Tech
OBP Limited
jcs are pretty good supposedly
Noximus is offline   Reply With Quote
Old 06-15-2015, 06:19 AM   #199
Noximus
Member#: 368550
2009 STI Sport Tech
OBP Limited
it should be in the same place
Old 06-15-2015, 02:56 PM   #200
SubiKidd04WRX
Member#: 423573
2004 Impreza WRX
Any good ones that aren't $140 lol
Uppipe FAQ: Read if you are thinking of buying one! Unabomber Newbies & FAQs 396 07-09-2020 02:25 AM
Pulley FAQ: Read if you are thinking of buying one! Unabomber Newbies & FAQs 120 01-29-2020 09:15 AM
Downpipe FAQ: Read if you are thinking of buying one! Unabomber Newbies & FAQs 338 10-25-2019 12:04 AM
Wheel FAQ: Read if you are thinking of buying some! Unabomber Newbies & FAQs 136 11-06-2017 08:56 AM
