04-22-2014, 09:50 AM | #101 | |
Member#: 3313
If you have a microcenter near you(you list the case as coming from them), you can get a MUCH MUCH better deal on processor/mobo from them. The i5-4670k can be had with the upgraded version of that motherboard for $235. If he just wants an SSD for boot, your 120Gb is a good option, with optical drives as storage. As for ram, only games and the most intensive stuff creeps over 8Gb of usage. Even games barely go over that. Yes, he can add 8Gb in the future. No, it does NOT need to be the same brand. It just has to match the same specs at whatever speed it's going to be run at(you can use faster ram and it'll just run at the slower clock if necessary). There can be some compatibility issues, but it's not generally a big deal as much anymore.
04-22-2014, 09:51 AM | #102 |
Member#: 212277
RMIC
I wouldn't necessarily abandon the discrete graphics card altogether, but I would perhaps consider a slower card -- a 650 is likely overkill for this application. I attempted to run my HTPC using the integrated graphics on an i5-4570S and I found general desktop performance to be a little laggy for my tastes.
I ended up buying one of these: http://www.amazon.com/Zotac-GeForce-mini-HDMI-Graphics-ZT-60408-20L/dp/B00D8Q3P0A/ref=sr_1_1?s=electronics&ie=UTF8&qid=1398174550&sr=1-1&keywords=zotac+gt+630 and I have been quite happy. |
04-22-2014, 09:55 AM | #103 | |
Member#: 34935
Vehicle:Dad- Core OG |
04-22-2014, 09:56 AM | #104 |
Member#: 82243
Vehicle:13' BMW X3 35i |
Something is wrong with your setup if your desktop was lagging with the integrated GPU. The integrated HD4600 in the i5 is pretty comparable to a GT630.
04-22-2014, 09:59 AM | #105 |
Member#: 3313
Yep, my HTPC uses an i3-3225, with the older HD4000 in it. I have had no issues with the video performance for Plex client playback, VLC playback, general desktop usage or such, on Windows 8.
For quite some time, they've been more than adequate for anything short of serious gaming or a few other GPU dependent tasks. |
04-22-2014, 10:05 AM | #106 |
Member#: 34873
reconfigured. Take 50 dollars off for the microcenter proc/mother combo by picking it up in store. Also forgot he wanted new speakers. Added that to the list at hte bottom.
PCPartPicker part list / Price breakdown by merchant / Benchmarks CPU: Intel Core i5-4670K 3.4GHz Quad-Core Processor ($199.99 @ Micro Center) Motherboard: MSI Z87-G41 PC Mate ATX LGA1150 Motherboard ($84.99 @ Micro Center) Memory: G.Skill Value 8GB (1 x 8GB) DDR3-1600 Memory ($64.99 @ Newegg) Storage: Crucial M500 120GB 2.5" Solid State Disk ($74.94 @ NCIX US) Case: Corsair 300R ATX Mid Tower Case ($39.99 @ Newegg) Power Supply: Corsair CX 500W 80+ Bronze Certified Semi-Modular ATX Power Supply ($34.99 @ Newegg) Monitor: Dell U2412M 60Hz 24.0" Monitor ($268.99 @ Amazon) Speakers: Logitech Z506 155W 5.1ch Speakers ($74.99 @ B&H) Total: $843.87 Microcenter in store pickup (50 dollars off) New total: 793.87 |
04-22-2014, 10:09 AM | #107 |
Member#: 3313
Why so expensive of a monitor? You can get a quality IPS panel for around $150-180 in the 23-24" range. Any particular reason? It won't be 1920x1200, but 1920x180. I doubt the average user would notice the difference.
I'm not telling you NOT to spend money on a nice monitor(I have two somewhat expensive ones at home), but unless that's something he specifically wants, you can save another $80-100 easily on that. Oh and the memory needs to be a 2x4GB kit. You want dual channel to be used, it's faster than using one single stick. |
04-22-2014, 10:13 AM | #108 |
Member#: 34935
Those Dells do seem to get consistently great reviews though...
04-22-2014, 10:14 AM | #109 |
Member#: 178811
Vehicle:2011 White Corolla Over 400hp |
All of my components arrived, ahead of schedule even! Got everything unpacked and ready to rock...and when time came to put the CPU cooler on I realized I didn't have the right brackets. D'oh! Ordered the AMD socket instead of the Intel socket...
Their professional UltraSharp series have been industry standard for years. If that Dell I picked out wasn't shipping original A00 revisions (4 years old with known display issues) I'd go for it. |
04-22-2014, 10:15 AM | #110 |
Member#: 212277
RMIC
Perhaps. I've always used discrete graphics cards so it's possible my initial impressions were a bit biased. I also could have spent more time in the BIOS tweaking settings and such. Either way, I noticed better performance with the discrete card. *shrug*
04-22-2014, 10:15 AM | #111 |
Member#: 178811
Dat double post doe.
04-22-2014, 10:19 AM | #112 |
Member#: 82243
I have two of those Dell monitors at work, really good.
Yea, I'm just saying you shouldn't have because the GPU you got was simply a sidestep not really an upgrade (even if it was discrete). |
04-22-2014, 10:32 AM | #113 | |
Member#: 34873
I will update the ram to dual channel, thanks for noticing that. Edit: someone recommended i go with this combo instead. I'm worried it might not be enough in terms of graphic processing power for the monitor. Any truth to that or would it work fine: Micro Center Combo 724591.614982 Combo Deal MSI Z87-G41 PC Mate ATX LGA1150 Motherboard$99.99 Combo Deal Intel Core i3-4340 3.6GHz Dual-Core Processor$129.99 Total:$229.98 Combo Discount:-$45.00 Combo Price:$184.98 NOTE: In-store pickup only Last edited by speelnik; 04-22-2014 at 11:16 AM. |
04-23-2014, 10:26 AM | #114 | |
Member#: 82243
04-23-2014, 10:30 AM | #115 |
Member#: 34935
Agreed, should be fine, but how much more is the i5?
04-23-2014, 11:24 AM | #116 |
Member#: 178811
Tired of waiting. I think I'm just going to throw the stock Intel cooler on and install W7/drivers tonight.
Already routed and zip-tied the cables - odds on mobo, ssd, gpu or something else being DOA? |
04-23-2014, 11:24 AM | #117 |
Member#: 156229
Any of you guys have your PC connected to a UPC? Thinking about picking one up as its thunderstorm and Air Conditioner season.
This is the one I was looking at. http://www.amazon.com/gp/product/B0038ZTZ3W/ref=ox_sc_act_title_1?ie=UTF8&psc=1&smid=ATVPDKIKX0DER |
04-23-2014, 11:28 AM | #118 |
Member#: 82243
Those are stepped approximation sine wave. For similar price get a pure sine wave system:
http://www.amazon.com/CyberPower-CP1000PFCLCD-Sinewave-Compatible-Mini-Tower/dp/B00429N192/ref=pd_cp_e_0 I run my PC and NAS on a cheapy units, both PCs have active PFC power supplies (which recommend pure sine wave UPS), if I had brown-outs or black outs I'd do a pure sine wave UPS, as it stands power is very stable so I haven't bothered upgrading either. |
04-23-2014, 04:53 PM | #119 |
Member#: 156229
You guys know of a good site/forum where can I upload a minidump file and they can tell me whats wrong? I've had this BSOD sporadically for almost 2 years.
04-23-2014, 05:05 PM | #120 |
Member#: 178811
04-24-2014, 12:08 AM | #121 |
Member#: 178811
Up and running! The memory booted fine in slots 2&4, but wouldn't accept the XMP profile for 2400MHz. Moved to slots 1&3 and the profile works fine...the slot 1 heatsink is touching my CPU cooler though.
Haven't touched the CPU frequency related things yet. |
04-27-2014, 07:04 PM | #122 |
Member#: 157348
Vehicle:I Thlammed My Penith in the Car Door |
Alright dudes, memtest is showing no errors in my RAM and my case has been all dusted out (there was very little dust to begin with as all of my intake fans have filters on them). Crashes and freezes getting more frequent. Any thoughts? Fresh install will be tough. I've moved three times since I built this thing and don't know where my computer parts box is.
04-27-2014, 07:05 PM | #123 | |
Member#: 16486
Vehicle:2006 Jeep |
on a side note, finally took the time and reorganized my HD's. moved the OS and boot back to the SSD and switched the raptor to PS scratch and other media. also cleaned up the other 4 backup drives and finally got Win 8.1 the way i like it. |
04-27-2014, 07:14 PM | #124 |
Member#: 157348
Yes. None of my temps have ever been above 35C if speedfan is correct.
It literally ONLY ****s up in Chrome. |
04-27-2014, 07:19 PM | #125 |
Member#: 86389
Vehicle:2011 WRX Hatch WRB |
I hate to say it but fresh install is likely the next step.. you could run a scan on the hard drive to make sure it's not bad sectors or the like but I kinda doubt it. I would remove/reinstall all the memory along with the CPU/Heatsink (with new thermal paste) before doing a fresh install but again, with no heat issues showing and memtest running well I doubt it will do much.
Power supply is a possibility as well, if one of the DC rails is under/over volting it could cause issues. |
