Old 03-26-2012, 07:34 PM   #26
camerong
Member#: 225101
2006 WRX TR
Originally Posted by TURBOvsV8 View Post
Has anyone tried the "H jumper" listed above? I did this on a 07 STI and foglights turn on with parking lights....add headlights....fogs and low beams work fine....but when I turn on the high beams with the fogs on the SBF No4. fuse under the dash blows.
I just did the "H jumper" nothing was cut. I can't understand why/if I cut the red wire with green stripe and connected it to power it would change my results? Can anyone help?
Same thing for me. Mine work great until I put my high beams on and the fuse blew for my DRL's and now the fogs wont turn on unless the low beams are on. Any suggestions? Add a fuse?
camerong is offline   Reply With Quote
Old 03-27-2012, 08:17 PM   #27
Big-E
Member#: 123843
2016 STI LTD CWP
Let LED's light your way!
Originally Posted by supra00400 View Post
followed this mod and everything went well except, now anytime that the key is in the ignition and switched to the on position, the fog lights stay on no matter if the switch is depressed or not. does this sound like a bad fog light switch? any and all help is appreciated.
When you say 'on' position, do you mean accessory or on as in ignition on?
If you mean ignition on, then it's possible the switch is bad.
Old 03-27-2012, 08:23 PM   #28
Big-E
Member#: 123843
2016 STI LTD CWP
The red wire with the green strip is in fact the ground wire from the high-beam switching relay located behind the glove-box.
When the car is running, with the headlamps off, there is power being fed to them. Subaru uses a switched ground system to control the headlamps.
Although off, there is power running through this circuit (red wire with green stripe) and it feeds the fog-lamp relay and switch. The relay so you can of course turn the lamps on and the switch so that when its turned on, the little green indicator lamp illuminates.
If for any reason you simply tap into the red wire with the green stripe and not fully disengage it from the relay (whether unlock or cut) you will effectively feed power backwards into the headlamp system, which will cause problems such as blowing fuses.
Old 03-30-2012, 03:08 PM   #29
camerong
Member#: 225101
2006 WRX TR
Good to know! Thanks for the info. Would you happen to know how to fix the problem? Maybe change the wire we tap into?
Old 03-31-2012, 01:51 PM   #30
Big-E
Member#: 123843
2016 STI LTD CWP
Do me a favor, state again which wire(s) you tapped into and how you tapped into them.
Don't repost; I want this to be neat and clean, if you know what I mean.
Old 09-24-2012, 01:36 PM   #31
jonnieoh
Member#: 333153
Default Need help with finding the correct high beam wire
I apologize to the OP for being slightly off-topic...
I have a 2002 WRX wagon, and have a pair of PIAA aftermarket driving lamps that I want to hook up to come on only when my high beams are activated by the stalk. I need to know exactly which wire I need to tap into to do this. I don't want to tap into the wrong one, and mess up my wiring enough to trip any fuses. My kit came with a wiring harness with its' own dashboard-mountable switch, and a "vampire clip", as I've seen it called on other threads here, to tap into a high beam wire.
Can you help me out with identifying the correct wire, (please be as specific as possible in your description). Better yet, photography of this wire would be really appreciated! Thanks so much everyone.
jonnieoh is offline   Reply With Quote
Old 09-26-2012, 08:43 AM   #32
jonnieoh
Member#: 333153
Bump.
Can anyone help a guy out, please?
"You're looking for the ______ wire with the ______ stripe, located in the ____________________."
Please fill in the blanks for me.
Old 09-26-2012, 01:00 PM   #33
Big-E
Member#: 123843
2016 STI LTD CWP
I'll look at the schematics this weekend.
In general, I will figure-out how to wire the switch so that when you turn the lamps on, they will only turn-on with the high-beams, and when you turn the car off, the lamps and switch will be dead; no possibility of any power-drain, whether the car is off or you have the key in the accessory position.
Old 09-26-2012, 01:09 PM   #34
jonnieoh
Member#: 333153
Thanks Big-E; I appreciate your help!!!
Old 10-07-2012, 07:23 AM   #35
Daddy_Digital
Member#: 274205
2013 XV Crosstrek
Orange
http://www.wrxtuners.com/forums/f73/...driving-15658/
click on this link, go to post # 2 and click on that link. Great DIY write with pictures.
Daddy_Digital is offline   Reply With Quote
Old 10-29-2012, 04:28 PM   #36
jonnieoh
Member#: 333153
Default not finished quite yet...
Hi all,
I followed the DIY, and was able to wire up my fog lamps so they can turn on with the low beams and the high beams. That is great! Thanks for that worthwhile mod.
BUT...
I also have my driving lamps installed, and they "work", but not the way I was hoping...
Like most driving lamp kits, they have their own dashboard-mounted, wired switch. They can currently be turned on or off via this switch, whether I have the low beams on, or the high beams on. It doesn't matter.
This isn't ideal.
Obviously, I'd really prefer that the driving lamps just come on automatically when I activate my high beams, (via the steering wheel-mounted stalk).
Said another way, I want to push the stalk forward to turn on the high beams, and at the same time, have the driving lamps automatically come on. Consequently, when I pull the stalk back to turn on the low beams, I want the driving lamps to turn off automatically. All of this should happen without having to touch the switch for the driving lamps at all.
Does that make sense?
So, WHAT WIRE DO I TAP INTO TO DO THIS, EXACTLY?:c onfused:
Currently, (having done the foglight mod), I've made a bridge between the orange wire in the fuse panel, to the red/green wire in the fog light relay. This bridge is currently where I've also connected my driving lamp wire.
Can anyone please help me? I cannot fathom that I'm the very first person to hook up driving lamps so that they work with the high beams on a 2002 WRX... Somebody has to have this answer out there in cyberspace!
Help me Obi-Wan, you're my only hope...
Old 10-30-2012, 02:56 AM   #37
CalvinT
Member#: 329025
2002 WRX Wagon
Originally Posted by jonnieoh View Post
Hi all,
BUT...
This isn't ideal.
You'll need to use a driving light relay. You should locate the relay near your driving lights. That will give you the shortest run from your battery to your driving lights. Be sure to have a fuse in the wire from the battery going to the relay contacts. You'll run two wires from the relay coil back to the dash. One wire will be connected with a vampire clip to the RED wire on your high-beam relay.
The RED wire is the switched ground for your high-beams. So your relay would pick up (turn on) when your headlights were turned on.
Connect the other wire to one side of your driving light switch. Connect the other side of your driving light switch to the GREEN WITH A WHITE STRIPE. This will make sure your driving lights are off when your ignition is off.
I'm not sure where the high-beam relay is located. Plus I'd like for someone to verify my thinking before anyone follows my suggestion.
Also I hope someone can write this up more clearly.
The large Green wire is from your ignition switch which turns on the ignition relay. The G/W wire is controlled by your ignition relay. Connecting to it gives more isolation from the rest of your system. Either should work.
You'll hook your driving lights from the driving light relay contacts to ground.
CalvinT is offline   Reply With Quote
Old 10-30-2012, 04:23 PM   #38
jonnieoh
Member#: 333153
Thanks CalvinT,
I feel like you've gotten me 90% of the way there, and with someone else's confirmation, I'd be in pretty good shape.
Old 10-31-2012, 03:28 PM   #39
CalvinT
Member#: 329025
2002 WRX Wagon
Thanks CalvinT,
You got me thinking. I've been wanting both fogs and driving lights for some time. Which PIAA lights did you get and where/how are you mounting them? I'll be installing Hella fog lights in the stock location.
Old 12-30-2012, 12:32 PM   #40
DenCon
Member#: 269472
Sick scoop light!
DenCon is offline   Reply With Quote
Old 12-31-2012, 08:41 PM   #41
CalvinT
Member#: 329025
2002 WRX Wagon
I just did the fog light relay conversion. I have a 2002 WRX. All my comments about fuse location and function are for a 2002 WRX. Your mileage may vary.
I cut both the RED WIRE WITH GREEN STRIPE (RG) that goes to the foglight relay and the RG wire that goes to the foglight switch. I folded back and taped off the car side of both RG wires so they wouldn't short out later.
I then connected the both RG wire from the switch and the RG wire from the relay to the GREEN (G) wire that goes to the ignition relay. It's the bottom relay in the relay block. (I should have used the GW wire, see warning about fuses below)
I could have used the GREEN WIRE WITH WHITE STRIPE (GW) wire but decided not to. There is no functional difference in using either the GREEN wire or GW wire if you get a good connection. (Again, see warning below)
The vampire clips I used were for 18-14 gauge wire. The GW wire seemed smaller than 18 gauge. The RG wires are 18 gauge. The GREEN wire seems to be either 14 or 16 gauge.
You won't get a good connection if you use a vampire clip with smaller wire than it's rated for. That could be one reason people had trouble when they tried connecting to the GW wire.
I left the ground connection to the switch stock. This allows me to use my fog lights the way I want and not the way the Government wants.
Now I can turn my fog lights on anytime the ignition is on. The indicator light comes on when the fog lights are on. If I turn on my high beam the fog lights go off. They also go off if I flash someone.
My next step is to connect a switch so i can turn off my Daytime Running Lights when I want. I disabled them, then realized they made me more noticeable, meaning someone is less likely to pull out in front of me. But i don't want them on if it's foggy.
****** WARNING ******
Be aware that the GREEN wire has a 50 A fuse (SBF-4 in the main fuse box) protecting it and the GW wire has a 15A fuse (No 5 in the main fuse box) protecting it. This means if you connect to the GREEN wire and the wiring you added later has a short to ground you may melt a wire and have a fire. If you connect to the GW wire and have a short you should be safe.
Having written that. I'll be moving my vampire clip tomorrow. I didn't fully research this until I decided to do this writeup.
Old 10-09-2013, 09:31 PM   #42
Culti
Member#: 248192
2007 STi
Can someone put a picture up or say which wire they tapped into for power for a 2007 STi?I'm using the same clip everyone's finding the orange wire from but don't see an orange wire? I was doing this and being that I have little to no electrical skill I had no idea which wire to grab power from... Thanks.
Culti is offline   Reply With Quote
Old 10-14-2013, 07:58 PM   #43
ckswanecamp
Member#: 299861
2002 Impreza WRX
Metallic Silver
Anybody else have the parking brake indicator slightly illuminated after completing this mod?
ckswanecamp is offline   Reply With Quote
Old 10-14-2013, 10:58 PM   #44
Big-E
Member#: 123843
2016 STI LTD CWP
Did you mean the high-beam indicator? If so, then yes, it will glow slightly.
My solution was to replace it with a high-output LED #74 equivalent bulb.
Old 10-26-2013, 08:41 PM   #45
ckswanecamp
Member#: 299861
2002 Impreza WRX
Metallic Silver
No its definitely the parking brake light. Annoying to have warning lights illuminated
Old 02-17-2014, 05:51 PM   #46
Subie_JDM
Member#: 361455
I'm confused. Where did the yellow wire that was installed with the vampire connector end up going to.
Subie_JDM is offline   Reply With Quote
Old 10-21-2014, 05:06 PM   #47
pat696
Member#: 343471
Default How To: 2002-2007 foglight mod (clean - no butcher job)
Just finished on an 07. Works great! Tapped into 1st relay green-white wire
Thanks for the guide
pat696 is offline   Reply With Quote
Old 10-17-2019, 10:07 PM   #48
GetWrxd01
Member#: 487728
2003 Wrx
Wrb
Originally Posted by Rayman812 View Post
it's not the green/white wire....the G/W wire is NOT an ignition power wire. the thicker gauge GREEN wire is however.
HOWEVER, there is one problem with this write-up. after u do what the OP says, the green indication light on the foglight button will no longer work. however, the foglights will work independently from the headlights.
to get around that, i simply "jump" the red/green wire with any ignition-only wire (in my case, solid green). dont need to cut anything, just simply add a splice that connects those 2 wires, and u get the fogs to come on w/o headlighs and the button indicator light remains working.
I spliced into the thicker all green wire, works great independently from my headlights. High beams on, parking lights, completely off etc. They shut off when I turn my car off. Thanks for the advice
GetWrxd01 is offline   Reply With Quote
How to: Install HID Conversion kit into 2007 WRX AxlxA Electrical & Lighting 45 07-22-2016 12:29 PM
How To: Remove eyelids/clean headlights SacksLax Interior & Exterior Modification 6 02-08-2009 01:38 AM
Fs Co- 2007 Wrx - Low Miles, One Owner, No Mods, Clean bigtexter Private Vehicle 'For Sale' Classifieds 4 01-31-2009 10:43 AM
How to: clean nasty/pitted fog/headlamp lenses imprezasti88 Interior & Exterior Modification 11 12-25-2005 01:15 PM
Foglight question\No, not the foglight mod. PntBllRS Interior & Exterior Modification 0 04-08-2002 12:02 AM
