03-19-2007, 10:51 AM | #1 |
Member#: 51480
International
Vehicle:1984 AM5, 1984 AF1, 1994 BC4, 2015 Outback |
EJ20G/EJ20K part number thread
I have access EUDM (up to 2005) and JDM (up to 2003) part CD-ROMs.
I can look up part numbers should you need any. Please always describe the part as clear as possibly, and state which model year. I can't promise I will look into this thread daily, but at least a few times a week. I will post the number as a reply to this thread, and will maintain a list in this first post. At your service Let me make clear that before you order anything based on the information and numbers I supply here, you should always double check with your supplier, to avoid disappointments!
03-19-2007, 12:40 PM | #2 |
n00b Moderator
Moderator Member#: 811
Vehicle:2000 RS-Ej20G It tastes like burning |
Thanks for setting this up. Would it make more sense to split the G and K motors to their own thread?
First request; Check if there is a different part # for the STi 1/2 HLA versus the standard WRX HLA. I have used this thread a few times for early G stuff (some may be liberyRS specific) http://www.rslibertyclub.org/forums/...ad.php?t=54967 -Rob |
03-19-2007, 02:55 PM | #3 |
Member#: 177
NWIC
Vehicle:The 93 W/EJ20K-sold Subaru-less :( |
car gc8d48d
build 5/97 engine EJ20KDW6HE tranny TY752VBCAA plug wires: -#1 - 22451AA793 not in system -#2,4 - 22452AA682 not in system -#3 - 22451AA822 not in system coil pack: 22433AA370 (1) 73.19 maf: 22680AA271 (1) 210.91 power steering lines -RHD 34610FA091 not in system -LHD 34610FA100 not in system ACCEL CABLE (EJ20K LHD): 37114FA070 not in system boost solenoid: 16102AA091 not in system map sensor: 22012AA160 (1) 219.39 iac: 22650aa132 not in system injectors: 16611AA231 not in system in fender overflow -tank 45152AA020 20.24 -filler 45132AA010 not in system -cap 45153AA001 3.39 pvc to block hose 807519082 head gasket: 11044AA355 (2) 27.78 sti reinforced head gasket: 11044AA463 not in system water pump gasget: 21114AA051 (1)1.93 rear main seal: 806786040 (1) 8.74 cam seals: 806732150 (4) 5.87 valve cover gasget: -right? 13270AA062 (1) 9.64 -left? 13272AA063 (1) 9.64 -?? 13293AA051 (4) 5.82 (says its for an 05-6 h6?) -wash rocker cvr (13271AA051 (12 or 16) 2.38 manifold to intake: 14035AA281 (2) 3.32 manifold to throttle body: 16175AA151 (1) 1.70 manifold to IAC: 22659AA060 (1) 3.88 manifold to injector: 16608AA020 (4) 5.22 crank -(#3 thrust bearing) 12200AA150 364.71 -(#5 thrust bearing) 12200AA2240 272.60 main bearings -(#3 thrust bearing) 12209AA000 84.80 -(#5 thrust bearing) 12209AA360 133.41 rod bearings: 12108AA290 182.80 rods 12100AA240 52.70 rings: 12033AA730 not in system head bolts: 11095AA041 7.26 rebuild gasket kit: 10105AA380 not in system heads -LH 11063AA742 not in system -RH 11039AB132 not in system cams (non STI) -13032AA240 not in system -13035AA240 not in system -13038AA240 not in system -13053AA240 not in system cams (STI) -13032AA390 not in system -13035AA390 not in system -13038AA390 not in system -13053AA390 not in system Non-RA valves: -EXH: 13202AA350 13.24 -INT: 13201AA340 9.21 vavle spring: 13217AA160 not in system rear deck cover -Up to July 1997: 65510FA001ML not in system -April 1997 on: 65510FA001OE not in system Last edited by Jaxx; 05-05-2007 at 12:51 PM. Reason: updated with info from below thanks! |
03-20-2007, 03:25 AM | #4 |
Member#: 51480
International
Plastic coolant tank on EJ20G intake manifold
TANK ASSEMBLY - WATER 21132AA001 (number is correct but not in Jamie's catalog) |
03-21-2007, 04:28 AM | #5 | |
Member#: 51480
International
22433AA370 COIL ASSY IGN (1) 22680AA271 METER AY-AIR FL (1) 11044AA355 GSKT-CYL HEAD (2) 21114AA051 GSKT-WATER PUMP (1) 806786040 OIL SEAL 86x103 (REAR CRANK SEAL) (1) 806732150 OILSEAL-32X45X8 (CAM SEAL) (4) 13270AA062 GSKT-ROCKER COV (1) 13272AA063 GSKT-ROCKER COV (1) 13293AA051 GSKT-ROCKER CVR (4) 13271AA051 WASH-ROCKER COV (12 or 16) 14035AA281 GSKT-INT MANIF (2) 16175AA150 GSKT-THROT CHAM (1) 22659AA060 GSKT-AIR CONT (1) 16608AA020 SEAL-FUEL INJEC (4) 34610FA091 P/S HOSE ASSY RHD (1) 34610FA100 P/S HOSE ASSY LHD (1) 16102AA091 VALVE AY - DUTY (1) 22012AA160 SEN ASSY-VAC (1) |
03-21-2007, 04:30 AM | #6 | ||
Member#: 51480
International
03-21-2007, 10:37 AM | #7 |
n00b Moderator
AHA! They are different numbers. The lightweight STi variant may exist afterall.
Thanks, Rob |
03-21-2007, 11:49 AM | #8 |
Member#: 832
RMIC
Vehicle:99 2.5RS, '85 911 '73 914 and 2012 BRZ |
very interesting...
03-21-2007, 10:15 PM | #9 |
Member#: 70256
RMIC
Vehicle:2000 STI V2 Swapped Silver |
Indeed....
03-21-2007, 11:27 PM | #10 |
Member#: 177
NWIC
WRX EJ20G HLA
13230AA160 ADJ CP-VLV LASH -28.45 STI V1/2 EJ20G HLA 13230AA170 ADJ CP-VLV LASH - not in system |
03-22-2007, 04:21 AM | #11 |
Member#: 51480
International
I couldn't find the STI HLA in my EUDM system / price list either. But I'm sure it can be ordered, they would just have to create the part number for the US or Europe. Parts tend to get expensive though (I once ordered a set of Spec C valve springs, which were 3 times as expensive as standard STI valve springs).
03-22-2007, 04:49 PM | #12 |
Member#: 11620
Vehicle:1997 GF4-STiV3 clone |
Marnix,
Would you be kind enough to look up the number for intake valves for a Version 4 Type R. The valves have a marking of "I H" on them. They are different from a version 3. Cheers, Bruce |
03-22-2007, 09:49 PM | #13 |
Guest
Member#:
WJM's request:
The 2003 JDM, STi Spec C Type RA standard size Pistons (92.0MM, for the A and B bore sizes) thanks! |
03-22-2007, 09:53 PM | #14 |
Guest
Member#:
03-22-2007, 11:50 PM | #15 |
Member#: 70256
RMIC
Marnix, could you get me the part number for the 90 degree rubber inlet piece that comes directly off the turbo? Thanks!
03-23-2007, 01:40 AM | #16 |
Member#: 78658
MWSOC
Vehicle:2005 LGT Limited Black/Black |
EJ20G part numbers for the rubber inlet peice off the turbo intake and all subsequent pieces from that point to the air box. thanks!
03-23-2007, 10:45 AM | #17 |
Member#: 832
RMIC
03-23-2007, 10:51 AM | #18 |
Guest
Member#:
But Marnix posted he can get up to 2003 JDM part numbers, that includes an EJ207....
03-23-2007, 12:41 PM | #19 |
Member#: 51480
International
EJ207 piston 'A' 12006AB430
EJ207 piston 'B' 12006AB440 But those are ridiculously expensive. |
03-23-2007, 12:45 PM | #20 |
Member#: 51480
International
03-23-2007, 12:50 PM | #21 |
Member#: 51480
International
03-23-2007, 01:58 PM | #22 |
Member#: 34545
MWSOC
Vehicle:1999 GC8 74f |
how about a IAC for a ej20g ver1
03-23-2007, 03:01 PM | #23 |
Guest
Member#:
Too bad those are not US part numbers. (pistons)
03-23-2007, 03:44 PM | #24 |
Member#: 11620
Got the # for the intake valves? Version 4 type R
03-23-2007, 06:03 PM | #25 |
Member#: 127307
MAIC
Vehicle:96 WRX Type R 555 Subaru Blue |
any chance you can copy those CD's?
Similar Threads | ||||
EJ20G & EJ20K Parts | awdeclipseguy | 1993 - 2001 Impreza Specific Parts | 17 | 06-15-2009 07:04 PM |
EJ20G Gasket Part Numbers... | scoobydorift | Subaru Conversions | 13 | 02-14-2005 10:43 PM |
Official XT Oil Filter Part Number thread | BrysImpreza | Forester Forum | 8 | 10-29-2003 11:23 PM |
NAPA Part numbers- can we have a nice thread with numbers listed? | Tex-WReX2 | Service & Maintenance | 5 | 12-15-2001 09:21 AM |
