Originally Posted by Powderhunter
Instead of putting one side on and trying the other you might need to try and get both sides on at the same time, probably takes another set of hands. You said you got the left side on and the right doesn't budge, if you do the right side does it look the same on the left as before?
Very rarely works on FB engines due to heat stress on the manifold. Best way is get one side on and pry the other.
I've tried all sorts of tricks. After 200-300 times I've tried everything and putting one end on/pry the other to spread is the easiest, best, and safest way to do it. The main problem is the flange twists some too (you can see that in the photo).
