Old 06-13-2013, 01:54 AM   #43
lymphomaniac
Member#: 334451
2018 WRX Sport CVT
CBS
Originally Posted by DIGGYGV8 View Post
test it on your car by having A/C enabled, press the button to disable, wait for 10 mins or so, re-enable manually, and listen for the compressor/relay click. Open your window, and park inside a parking lot if you have to.
Sorry, Bud. Confirmed that MY 13 2.0i will not allow me to disable a/c on defrost mode. I tried it this evening, and there was definitely something bogging down the engine even after I tried to turn the a/c off. Either something else is running in the background (in addition to a/c) while on defrost, or the a/c didn't disengage. I'm thinking it's likely the latter, given the cold air blowing out of the vents.
Since MY 13 2.0i is just a re-badged MY 12 2.0i with minor edits, I suspect the same holds true for MY 12 2.0i.
lymphomaniac is offline   Reply With Quote
