Old 06-17-2020, 03:06 AM   #2
cbishop
Member#: 514985
Default Lifting assistance
You probably want to read through the Impreza Lift posting which has quite a bit of the component listed for various lifts people have done. How much lift are you looking to do? I believe around the most you can do is 2" in the suspension without having challenges with the angles for the drive components. You can also get another 1+ inch with larger tires.
I have a 2015 wagon and I'll be putting a 2" lift and bump the tires from the 205-55-16 stock to 215-65-16. I bought a complete lift kit with alignment correction from Rallitech and am hiring a local mechanic to do the work plus the alignment after. Should get almost 3 extra inches of ground clearance and a more aggressive look.
cbishop is offline   Reply With Quote
