1. Timing belt is fine. Not my first, I gave the engine several full rotations and checked before droppinwg into the car, and checked it again after the first time I ran it. I've had a skipped tooth before on a phase 1 EJ22, and it was pretty darn noticeable. Not "once in a while I get a misfire code"
2. What is there to check ons the crank sensor? WOuldn't a problematic one produce all kinds of errors?
3.
Originally Posted by Gamil
I did gap the plugs today and they all measured fine. But, #2 is slightly sooty. The rest looked perfect (no soot, no oil, no white spots, just brown/grey which the FSM says is the norm)
I'm using a new set of the same NGK Iridiums that I had used for the preceeding 50,000 miles without a single code.
4. Shop intalled the valves, stem seals and retainers. I installed the cams. I Read the FSM procedure 3 times before starting, and then started following it one step at a time. Assembly lube, torque specs and sequence.
5. Why would a brand new harness from dealer not be intact? I was running the engine on the old harness with the O2 sensor and knock sensor connectors taped together until after about 300 miles I started getting a "low voltage" code on the knock sensor. I figured it was because a jerry-rigged connector just wasn't staying together. Once I replaced both knock sensor and harness with brand NEW OEM parts, then I started getting the mis-fire code
