Basically what it says in the title. My rear windshield washer has stopped spitting out any washer fluid. I can hear the motor running when I use the control, but nothing is coming out.
On the impreza there isn't a separate rear reservoir, right? It's just the front reservoir feeding both the front and rear washers? I'm not out of washer fluid since the front washer works fine.
I guess it could either be a bad hose or a bad washer tip.
Where do the hoses for the rear washer even go? Do they go through the headliner?
