I got the misfire codes on my 00' RS on 3 and 4- I reset about 3 times and they would come back every 2 or 3 days-replaced the ignition wires and it hasn't come back in 2 weeks. I got Magnecor KV85's since they are the same price or cheaper than OEM subaru wires. If you have an ohm meter, pull the wires and check continuity on them, (should read a few thousand ohms) My #3 wire was open internally, and since 3 and 4 share a common coil with wasted spark, this was my problem. Also, check your coil pack secondaries resistance across 1-2 and 3-4 (should also read a few thousand ohms) If 1-2 and 3-4 are not within say 20% of each other, you MIGHT have damage to your pack. Testing the coil primaies depends on wether yours is 3 terminal or 4 terminal IIRC. Hope this helps- Andy
