Originally Posted by STiWanabe
No mystery there. He told me he launched it and roasted the clutch.
6MT clutch and flywheel.
competition clutch, pressure plate, throwout bearing, and pilot bearing. Exedy OEM replacement flywheel.
OK, so . . . are you sure you have the correct size throwout bearing? Wrong size bearing will cause issues like you described.
Have had mechanics install wrong throwout bearing before and when I took it back they couldn't figure it out. I was right there the whole time they kept trying different combinations.
Then near the end of the day I said, " Are you sure you put in the correct throwout bearing? ". Sure enough, that was the issue.
