Hi all
EDITED & Updated Nov 25, 2009
ECU / Tuning
Link(aka ViPEC) PnP ECU - BNIB never installed full Plug and Play incl. anti lag, lambda control, etc. works in WRX02-05 or JDM STI 01-07 or EDM WRX/STI 01-07 $1000
Link(aka ViPEC) PnP ECU - never installed full Plug and Play incl. anti lag, lambda control, etc. works in WRX02-05 or JDM STI 01-07 or EDM WRX/STI 01-07 but put in a case to be used as rally car spare $900
Motec PnP ECU - installed once fully working with all options Lambda, launch, avcs, ALS, etc. $2500 (new is $4k+) WRX02-05 or JDM or EDM 01-07 WRX or STI **and** with purchaseable option for DBW to control MY06+ WRX and/or MY04-07 STI
GEMS PnP ECU - fully working with all MOTORSPORT options for WRX02-05 or JDM or EDM 01-07 WRX or STI $2000 (new is $4k+) note this is not the 'ghetto consumer version' or AEM version this is the real deal !
Link V2 wire in ECU BNIB including harness $1000
1 - Ver 1. 2004 STi Cobb AP guaranteed to be unmarried. $150
1 - Ver 1. 2005 STi Cobb AP guaranteed to be unmarried. $150
1 - WRX UTEC customer take off - best offer
1 - WRX UTEC customer take off fully complete with all standoff bolts etc - best offer
1 - STi UTEC customer take off - best offer
6 - AF42x ECUs for 02-03 WRX (reflashable to 03 but why on earth would you do that because the 0-2 firmware is better). $95 ea.
2 - AJ24x ECUs for 04 STi. $150 ea.
1 - set complete LGT 5EAT ECU, keys, body unit (for immobilizer) and cluster for a complete setup $450
1 - Apexi AVC-R - best reasonable offer
Interior (all MY08 stuff is BRAND NEW take-offs, from the cars we recently received for builds, all zero mileage only "storage" miles)
2 x MY08 STI rear seats incl. back cusion and seat cushions $200 ea set
2 x MY08 STI rear cargo covers $50
2 x MY08 STI fuel tanks (complete assy) $250
2 x MY08 STI fuel pumps and fuel pump controllers and control assy $250
2 x MY08 STI headliners $50
2 x MY08 STI nav units (GPS, DVD, stereo head unit, Sat radio) $BO
2 x MY08 STI full interior carpet $100
2 x MY08 STI full rear carpet cover & foam stuff $50
2 x MY08 center consoles $50
2 x MY08 STI handbrake console & assembly (SI drive switch removed) $50
2 x MY08 full seat belt set. WILL NOT PART OUT. $BO
2 x MY08 sterring wheels w/ airbag WILL NOT PART OUT
1 x set Recaro seat rails for GC installed for 2 months - best offer
6point racing harnesses, FIA expired but never crashed ! You can get them inspected and re-certified to be FIA legal if you wish, perfect for track days.
1 set of near new 2001 RS seats. take off from a rally build. MAKE AN OFFER
1 set of excellent (<40,000km) 03 WRX rear seats
1 pair of very good (<50,000km) 02 WRX front seats
1 set of GC doors for 4 door in seafoam green includes everything like windows, etc. ready to bolt on - $400
5 - complete MY02 impreza interiors *no part outs*
3 - complete MY04 STI trunk interiors *no part outss*
3 - complete MY04 STI rear interiors *no part outs*
2 - complete GC 98 RS interiors *no part outs*
4 - complete set of airbags for Subarus
Auto Trans
*ALL BELOW MUST GO FOR BEST OFFER, MAKE OFFER VIA PM **
1 x 4EAT perfect condition includes torque converter - pulled out of a 35,000km WRX for a 6spd conversion *fully running perfectly when pulled*
1 x 4EAT TCU (from above project)
1 x 4EAT pulled for a swap but higher mileage, 70,000km
1 x 5EAT valve body (pulled out an LGT for a 6MT swap)
** WE HAVE A NEW TIRE ARRANGEMENT FOR 2010 SO WE NEED TO BLOW OUT OUR MOTORSPORT TIRES **
Competition Tires - Gravel
200+ used Michelin ZA8 R and L competition rally gravel tires, only used for <30 km each, condition varies $50 and up
50+ used Michelin ZA7 R and L competition rally gravel tires, only used for <30km each, condition & cost varies $50 and up
20 used Pirelli K6 (in KM6 pattern) R and L competition gravel rally tires, only used <20km each, EXCELLENT CONDITION
24 used BFG GZS4 R and L PLUS 4 new ones (these are narrow suitable for WRX etc), from beat to very good condition
30+ used BFG GZG4 R and L (this is the NEW tire just release 3 months ago) in very good condition
8 new (same as above)
Competition Tires - Tarmac
Various assortment of 17" and 18" tarmac slicks in rain and cut and full slick as well as Pikes Peak spec, all in very good to excellent condition
Also have mounted but never heat cycled / rallied:
4 x Michelin TA01 17"
8 x Michelin TA04 17"
4 x Michelin N02 17"
6 x BFG N2 18"
Winter Competition Tires
16 "ANDROS" tires (as used in ANDROS tropy racing) narrow studded 16" in excellent condition <-- $100/per
12 EXCELLENT never rallied ! sweeden - spec (20mm studs!, 600+ per tire) 16" rally tires Michelin & Pirelli NEW cost $450/per will go now $225 <--STEAL
12 Continental Andros2 spec tires (16" studded, less studs than above) <-- $100/per
12 Continental Andros2 spec tires with no studs (16") <-- $75/per
** all of above tires mount to 16x5.5" "sweeden spec rims" - they clear the 4pots/MY06WRX and AP MY08+ Grp N brakes but DO NOT CLEAR Brembos **
we have these rims new in stock as well $289 per in 5x100 and 5x114.3 but limited stock
18 Yokohama AO34 15" **THE**studless ice tires of choice. Never driven on but mounted once $215/per (reg. $235)
Blocks / Internals
Various Decent blocks in 2.0L and 2.5L some will require hand hone some possibly bore $100-$300 each:
8+ EJ20 shortblocks no pistons - all good for rebore includes both haves and bolts - make offer no lowballs because we will use these
8+ EJ25 shortblocks no pistons etc all good for rebore - all good for rebore includes both halves and bolts - make offer no lowballs because we will use these
1 x Mahle Piston set never used / never installed customer bought and opened box and tried to install realizing he bought the wrong bore (i.e. opened the box, got it hand dirty) $350
3 x Mahle piston sets for WRX / STI all BNIB $BO
Engine Top
15 - WRX intercoolers $70. Does not include hoses. Some might, but we aren't guaranteeing hoses.
5 - WRX intake manifolds, no sensors included. $120
2 - USDM STi intake manifolds, no sensors included. $240
8 - USDM STi Intakes - NO MAF - $125
2 - JDM early ver. Slant Intercoolers (small) - make offers
Brakes
24+ used WRX front rotors in various stages of use (work with 4 pots) - $25 each (just over scrap metal value). Perfect for rally spares.
18+ used 2 pot rear rotors (5x100) in various stages of use (work with 06+ or people with JDM conversions) - $25 each (just over scrap metal value). Perfect for rally spares.
2004 STI Front and Rear Rotors:
We have 17 rears and 9 front rotors also stock pads for these "**BRAND NEW IN BOX NEVER OPENED*"
Drivetrain
4 - prodrive 4 dog mainshafts for 6spd case *brand new never used* if you want this, you know how much they cost. 50% of cost. if you dont know how much they cost, you dont want it.
9 - prodrive 4 dog dog rings for 6spd case *brand new never used* same as above for pricing
9 - R160 rear diffs, in both 3.90 and 4.44 and 4.11. No LSDs included so please dont PM asking for "kazz" or "sti" or LSD. These are all good rear diffs and housings. All OBO.
3 - R180 rear diffs, all in 3.90. best offers, all with STI clutch pack diff (tested & good).
3 - R180 rear diff, in 3.54. best offers, some suretrack (tested & good), some with clutch pack (tested & good).
4 - 5MT transmission cases. All three styles (i.e. "old", "new" and "after 02 build date new")
3 - complete 6MT gear sets. Assembled main and lay shafts only. USDM gears. only have break in miles (i.e. <200 km). Perfect for a guy who shredded his 6MT. $1800 ea.
There is tons more. If you need something DO NOT HESITATE TO ASK/PM we have too much stock.
FYI these are pickup prices, PLEASE PICKUP IF YOU CAN. Local same day courier service is so cheap you should use it. For that service, for large / heavy / hard to pack / hard to ship items there may be a handling fee but really that wont happen unless we get dinged. UPS and/or other shipping methods will have a handling fee its not a BNIB item.
