Old 05-07-2020, 08:06 AM   #2
Cujo31
Member#: 19843
2000 2.5 RS Sedan
2016 Base 5MT VRP
even though you say turning doesn't change the sound, i'd probably replace the wheel bearings since it's a common problem for them to go bad
alignment and balance, make sure your rear differential bushings aren't cracked/broken... check the CV axles, maybe replace 'em...
hard to tell without seeing/hearing it in person... also really look around for anything rubbing on the underside..
good luck
Cujo31 is offline   Reply With Quote
