the lights worked fine the first day after having this car, then i cleaned the interior and now there are no running lights or dash lights. headlights work, turn signals work. Checked all the fuses, they are good. When you turn the headlight switch to first position (running lights) you can hear a click under rh side of dash but no lights (dash/running). They also don't come on from the switch on top of the column. Has anyone had this isssue or have access to running light wiring diagram?
