Originally Posted by SeeeeeYa
You realise of course, that when you switched tunes... your trims were reset.
Did you then run your car normally long enough to have the new tune's trims stabilised? Otherwise your logs may be misleading.
Yes sir- I am aware. There's a good bit of mixed driving, highway city, intentional open loop throttle sweeps and idle learning on each before taking a log. In the hundreds of miles for all but the "rich" tune. Which I will re-log once it has more than about 50 miles on it, which it did during the log I posted above.
This was not a case of log, pull over, reflash, log etc.
