Originally Posted by kakarot09
I would pull the cam gears back off and see if you didn't align the dowel pin on the cam inside the cam gear. I've seen this twice before where the dowel pin wasn't in the hole it's supposed to be.
The gears can get damaged multiple ways, pull one and look down the barrel. Mine were bad from installation, when tightened they “mushed” the metal into the next hole, elongating the dowel hole and almost closing an oil port
